man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_SignalDownSample_S16S_S16S (3MLIB)
Name
mlib_SignalDownSample_S16_S16, mlib_SignalDownSample_S16S_S16S, mlib_SignalDownSample_F32_F32, mlib_SignalDownSample_F32S_F32S - signal downsampling
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalDownSample_S16_S16(mlib_s16 *dst,
     const mlib_s16 *src, mlib_s32 factor, mlib_s32 phase,
     mlib_s32 n);
mlib_status mlib_SignalDownSample_S16S_S16S(mlib_s16 *dst,
     mlib_s32 n);
mlib_status mlib_SignalDownSample_F32_F32(mlib_f32 *dst,
     const mlib_f32 *src, mlib_s32 factor, mlib_s32 phase,
     mlib_s32 n);
mlib_status mlib_SignalDownSample_F32S_F32S(mlib_f32 *dst,
     mlib_s32 n);
Description
Each of these functions performs downsampling.
For monaural signals, the following equation is used:
dst[i] = src[i*factor + phase]
where i = 0, 1, ..., (n - 1 - phase)/factor.
For stereo signals, the following equation is used:
dst[2*i]     = src[2*(i*factor + phase)]
dst[2*i + 1] = src[2*(i*factor + phase) + 1]
Parameters
Each of the functions takes the following arguments:
dst
Output signal array.
src
Input signal array.
factor
Factor by which to downsample. factor ≥ 1.
phase
Parameter that determines relative position of an output value, within the input signal. 0 ≤ phase < factor.
n
Number of samples in the input signal array.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_SignalUpSample_S16_S16(3MLIB), attributes(5)
