cc [ flag... ] file... –lmlib [ library... ] #include <mlib.h> mlib_status mlib_GraphicsDrawEllipse_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c);
mlib_status mlib_GraphicsDrawEllipse_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c);
mlib_status mlib_GraphicsDrawEllipse_X_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsDrawEllipse_X_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsDrawEllipse_A_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c);
mlib_status mlib_GraphicsDrawEllipse_A_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c);
mlib_status mlib_GraphicsDrawEllipse_B_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c, mlib_s32 alpha);
mlib_status mlib_GraphicsDrawEllipse_B_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c, mlib_s32 alpha);
mlib_status mlib_GraphicsDrawEllipse_AB_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c, mlib_s32 alpha);
mlib_status mlib_GraphicsDrawEllipse_AB_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c, mlib_s32 alpha);
Each of the mlib_GraphicsDrawEllipse_*() functions draws an ellipse with the center at (x, y), major semiaxis a, and minor semiaxis b. The angle of the major semiaxis is t counterclockwise from the X axis.
Each of the mlib_GraphicsDrawEllipse_X_*() functions draws an ellipse in Xor mode as follows:
data[x,y] ^= c ^ c2
Each of the mlib_GraphicsDrawEllipse_A_*() functions draws an ellipse with antialiasing.
Each of the mlib_GraphicsDrawEllipse_B_*() functions draws an ellipse with alpha blending as follows:
data[x,y] = (data[x,y] * (255 - alpha) + c * alpha) / 255
Each of the mlib_GraphicsDrawEllipse_A_*() functions draws an ellipse with antialiasing and alpha blending.
Each of the functions takes some of the following arguments:
Pointer to the image into which the function is drawing.
X coordinate of the center.
Y coordinate of the center.
Major semiaxis of the ellipse.
Minor semiaxis of the ellipse.
Angle of major semiaxis in radians.
Color used in the drawing.
Alternation color.
Alpha value for blending. 0 ≤ alpha ≤ 255.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_GraphicsDrawArc(3MLIB), mlib_GraphicsDrawCircle(3MLIB), attributes(5)
