cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoInterpY_U8_U8(mlib_u8 *curr_block,
const mlib_u8 *ref_block, mlib_s32 width, mlib_s32 height,
mlib_s32 frm_stride, mlib_s32 fld_stride);
The mlib_VideoInterpY_U8_U8() function performs half-pixel interpolation in the Y direction for a reference block of data type mlib_u8 and a current block of data type mlib_u8. In this mode, the motion-compensated reference block becomes the current block. Thus, the stride applies to both the input reference block and the current block.
The function takes the following arguments:
Pointer to the current block. curr_block must be 8-byte aligned.
Pointer to the reference block.
Width of the blocks.
Height of the blocks.
Stride, in bytes, between adjacent rows in a frame in both the current block and reference block. frm_stride must be a multiple of eight.
Stride, in bytes, between adjacent rows in a field in both the current block and reference block. fld_stride must be a multiple of eight.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_VideoAddBlock_U8_S16(3MLIB), mlib_VideoCopyRef_S16_U8(3MLIB), mlib_VideoCopyRef_S16_U8_16x16(3MLIB), mlib_VideoCopyRef_U8_U8(3MLIB), mlib_VideoCopyRef_U8_U8_16x16(3MLIB), mlib_VideoCopyRefAve_U8_U8(3MLIB), mlib_VideoCopyRefAve_U8_U8_16x16(3MLIB), mlib_VideoH263OverlappedMC_S16_U8(3MLIB), mlib_VideoH263OverlappedMC_U8_U8(3MLIB), mlib_VideoInterpAveX_U8_U8(3MLIB), mlib_VideoInterpAveX_U8_U8_16x16(3MLIB), mlib_VideoInterpAveXY_U8_U8(3MLIB), mlib_VideoInterpAveXY_U8_U8_16x16(3MLIB), mlib_VideoInterpAveY_U8_U8(3MLIB), mlib_VideoInterpAveY_U8_U8_16x16(3MLIB), mlib_VideoInterpX_S16_U8(3MLIB), mlib_VideoInterpX_S16_U8_16x16(3MLIB), mlib_VideoInterpX_U8_U8(3MLIB), mlib_VideoInterpXY_S16_U8(3MLIB), mlib_VideoInterpXY_S16_U8_16x16(3MLIB), mlib_VideoInterpXY_U8_U8(3MLIB), mlib_VideoInterpXY_U8_U8_16x16(3MLIB), mlib_VideoInterpY_S16_U8(3MLIB), mlib_VideoInterpY_S16_U8_16x16(3MLIB), mlib_VideoInterpY_U8_U8_16x16(3MLIB), mlib_VideoP64Decimate_U8_U8(3MLIB), mlib_VideoP64Loop_S16_U8(3MLIB), mlib_VideoP64Loop_U8_U8(3MLIB), attributes(5)
