cc [ flag... ] file... –lmlib [ library... ] #include <mlib.h> mlib_status mlib_GraphicsFillArc_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c);
mlib_status mlib_GraphicsFillArc_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c);
mlib_status mlib_GraphicsFillArc_X_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsFillArc_X_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsFillArc_A_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c);
mlib_status mlib_GraphicsFillArc_A_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c);
mlib_status mlib_GraphicsFillArc_B_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsFillArc_B_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsFillArc_AB_8(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsFillArc_AB_32(mlib_image *buffer, mlib_s16 x, mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c, mlib_s32 a);
Each of the mlib_GraphicsFillArc_*() functions draws a filled arc with the center at (x, y), radius r, start angle t1, and end angle t2.
Each of the mlib_GraphicsFillArc_X_*() functions draws a filled arc in Xor mode as follows:
data[x,y] ^= c ^ c2
Each of the mlib_GraphicsFillArc_A_*() functions draws a filled arc with antialiasing.
Each of the mlib_GraphicsFillArc_B_*() functions draws a filled arc with alpha blending as follows:
data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Each of the mlib_GraphicsFillArc_AB_*() functions draws a filled arc with antialiasing and alpha blending.
Each of the functions takes some of the following arguments:
Pointer to the image into which the function is drawing.
X coordinate of the center.
Y coordinate of the center.
Radius of the arc.
Start angle of the arc in radians.
End angle of the arc in radians.
Color used in the drawing.
Alternation color.
Alpha value for blending. 0 ≤ a ≤ 255.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_GraphicsFillCircle(3MLIB), mlib_GraphicsFillEllipse(3MLIB), attributes(5)
