cc [ flag... ] file... –lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageConstXor_Inp(mlib_image *srcdst, const mlib_s32 *c);
The mlib_ImageConstXor_Inp() function computes the exclusive Or of the source image with a constant on a pixel-by-pixel basis, in place.
It uses the following equation:
srcdst[x][y][i] = c[i] ^ srcdst[x][y][i]
The data type of the images can be MLIB_BIT, MLIB_BYTE, MLIB_SHORT, MLIB_USHORT, or MLIB_INT.
The function takes the following arguments:
Pointer to first source and destination image.
Array of constants to be applied to each pixel. c[i] contains the constant for channel i.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
