man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_SignalConvertShift_U8S_F32S_Sat(3MLIB)
Name
mlib_SignalConvertShift_U8_S8_Sat, mlib_SignalConvertShift_U8_S16_Sat, mlib_SignalConvertShift_U8_S32_Sat, mlib_SignalConvertShift_U8_F32_Sat, mlib_SignalConvertShift_U8S_S8S_Sat, mlib_SignalConvertShift_U8S_S16S_Sat , mlib_SignalConvertShift_U8S_S32S_Sat, mlib_SignalConvertShift_U8S_F32S_Sat, mlib_SignalConvertShift_S8_U8_Sat, mlib_SignalConvertShift_S8_S16_Sat, mlib_SignalConvertShift_S8_S32_Sat, mlib_SignalConvertShift_S8_F32_Sat , mlib_SignalConvertShift_S8S_U8S_Sat, mlib_SignalConvertShift_S8S_S16S_Sat, mlib_SignalConvertShift_S8S_S32S_Sat, mlib_SignalConvertShift_S8S_F32S_Sat, mlib_SignalConvertShift_S16_U8_Sat, mlib_SignalConvertShift_S16_S8_Sat , mlib_SignalConvertShift_S16_S32_Sat, mlib_SignalConvertShift_S16_F32_Sat, mlib_SignalConvertShift_S16S_U8S_Sat, mlib_SignalConvertShift_S16S_S8S_Sat, mlib_SignalConvertShift_S16S_S32S_Sat, mlib_SignalConvertShift_S16S_F32S_Sat , mlib_SignalConvertShift_S32_U8_Sat, mlib_SignalConvertShift_S32_S8_Sat, mlib_SignalConvertShift_S32_S16_Sat, mlib_SignalConvertShift_S32_F32_Sat, mlib_SignalConvertShift_S32S_U8S_Sat, mlib_SignalConvertShift_S32S_S8S_Sat , mlib_SignalConvertShift_S32S_S16S_Sat, mlib_SignalConvertShift_S32S_F32S_Sat - data type convert with shifting
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalConvertShift_U8_S8_Sat(mlib_u8 *dst,
     const mlib_s8 *src, mlib_s32 shift, mlib_s32 n);
mlib_status mlib_SignalConvertShift_U8_S16_Sat(mlib_u8 *dst,
     const mlib_s16 *src, mlib_s32 shift, mlib_s32 n);
mlib_status mlib_SignalConvertShift_U8_S32_Sat(mlib_u8 *dst,
     const mlib_s32 *src, mlib_s32 shift, mlib_s32 n);
mlib_status mlib_SignalConvertShift_U8_F32_Sat(mlib_u8 *dst,
     const mlib_f32 *src, mlib_s32 shift, mlib_s32 n);
mlib_status mlib_SignalConvertShift_U8S_S8S_Sat(mlib_u8 *dst,
mlib_status mlib_SignalConvertShift_U8S_S16S_Sat(mlib_u8 *dst,
mlib_status mlib_SignalConvertShift_U8S_S32S_Sat(mlib_u8 *dst,
mlib_status mlib_SignalConvertShift_U8S_F32S_Sat(mlib_u8 *dst,
mlib_status mlib_SignalConvertShift_S8_U8_Sat(mlib_s8 *dst,
     const mlib_u8 *src, mlib_s32 shift, mlib_s32 n);
mlib_status mlib_SignalConvertShift_S8_S16_Sat(mlib_s8 *dst,
mlib_status mlib_SignalConvertShift_S8_S32_Sat(mlib_s8 *dst,
mlib_status mlib_SignalConvertShift_S8_F32_Sat(mlib_s8 *dst,
mlib_status mlib_SignalConvertShift_S8S_U8S_Sat(mlib_s8 *dst,
mlib_status mlib_SignalConvertShift_S8S_S16S_Sat(mlib_s8 *dst,
mlib_status mlib_SignalConvertShift_S8S_S32S_Sat(mlib_s8 *dst,
mlib_status mlib_SignalConvertShift_S8S_F32S_Sat(mlib_s8 *dst,
mlib_status mlib_SignalConvertShift_S16_U8_Sat(mlib_s16 *dst,
mlib_status mlib_SignalConvertShift_S16_S8_Sat(mlib_s16 *dst,
mlib_status mlib_SignalConvertShift_S16_S32_Sat(mlib_s16 *dst,
mlib_status mlib_SignalConvertShift_S16_F32_Sat(mlib_s16 *dst,
mlib_status mlib_SignalConvertShift_S16S_U8S_Sat(mlib_s16 *dst,
mlib_status mlib_SignalConvertShift_S16S_S8S_Sat(mlib_s16 *dst,
mlib_status mlib_SignalConvertShift_S16S_S32S_Sat(mlib_s16 *dst,
mlib_status mlib_SignalConvertShift_S16S_F32S_Sat(mlib_s16 *dst,
mlib_status mlib_SignalConvertShift_S32_U8_Sat(mlib_s32 *dst,
mlib_status mlib_SignalConvertShift_S32_S8_Sat(mlib_s32 *dst,
mlib_status mlib_SignalConvertShift_S32_S16_Sat(mlib_s32 *dst,
mlib_status mlib_SignalConvertShift_S32_F32_Sat(mlib_s32 *dst,
mlib_status mlib_SignalConvertShift_S32S_U8S_Sat(mlib_s32 *dst,
mlib_status mlib_SignalConvertShift_S32S_S8S_Sat(mlib_s32 *dst,
mlib_status mlib_SignalConvertShift_S32S_S16S_Sat(mlib_s32 *dst,
mlib_status mlib_SignalConvertShift_S32S_F32S_Sat(mlib_s32 *dst,
Description
Each of these functions performs data type convert with shifting.
The following equation is used:
dst[i] = saturate(src[i] * 2**shift)
See the following tables for available variations of this group of data type convert functions.
Type [*]
U8
S8
S16
S32
U8
Y
Y
Y
S8
Y
Y
Y
S16
Y
Y
Y
S32
Y
Y
Y
F32
Y
Y
Y
Y
Type [*]
U8S
S8S
S16S
S32S
U8S
Y
Y
Y
S8S
Y
Y
Y
S16S
Y
Y
Y
S32S
Y
Y
Y
F32S
Y
Y
Y
Y
[*] Each row represents a source data type. Each column represents a destination data type.
Parameters
Each of the functions takes the following arguments:
dst
Destination signal array.
src
Source signal array.
shift
Left shifting factor.
n
Number of samples in the source signal arrays.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_SignalConvertShift_F32_U8(3MLIB), attributes( 5)
