man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_SignalIIR_P4_F32S_F32S(3MLIB )
Name
mlib_SignalIIR_P4_S16_S16_Sat, mlib_SignalIIR_P4_S16S_S16S_Sat, mlib_SignalIIR_P4_F32_F32, mlib_SignalIIR_P4_F32S_F32S - parallel Infinite Impulse Response (IIR) filtering
Synopsis
cc [ flag... ] file... –
lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalIIR_P4_S16_S16_Sat(
mlib_s16 *dst,
     const mlib_s16 *src, void *
filter, mlib_s32 n
mlib_status mlib_SignalIIR_P4_S16S_S16S_Sat
(mlib_s16 *dst,
filter, mlib_s32 n
mlib_status mlib_SignalIIR_P4_F32_F32(
mlib_f32 *dst,
     const mlib_f32 *src, void *
filter, mlib_s32 n
mlib_status mlib_SignalIIR_P4_F32S_F32S(
mlib_f32 *dst,
filter, mlib_s32 n
Description
Each of these functions applies a fourth order parallel IIR filter to one signal packet and updates the filter state.
image:Equation that represents the fourth order parallel IIR filtering
The fourth order parallel IIR filter is represented by the following figure:
image:Figure that represents the fourth order parallel IIR filter
Parameters
Each of the functions takes the following arguments:
dst
Destination signal array.
src
Source signal array.
filter
Internal filter structure.
n
Number of signal samples.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_SignalIIR_Biquad_S16_S16_Sat(3MLIB), mlib_SignalIIRFree_Biquad_S16_S16(3MLIB), mlib_SignalIIRFree_P4_S16_S16(3MLIB), mlib_SignalIIRInit_Biquad_S16_S16(3MLIB), mlib_SignalIIRInit_P4_S16_S16(3MLIB), attributes(5)
