cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoColorJFIFYCC2ABGR444(mlib_u8 *abgr,
const mlib_u8 *y, const mlib_u8 *cb,
const mlib_u8 *cr, mlib_s32 n);
The mlib_VideoColorJFIFYCC2ABGR444() function performs color space conversion from YCbCr to ABGR when used in the JPEG File Interchange Format (JFIF).
The following equation is used:
A = 0xFF R = Y + 1.40200 * (Cr - 128) G = Y - 0.34414 * (Cb - 128) - 0.71414 * (Cr - 128) B = Y + 1.77200 * (Cb - 128)
The function takes the following arguments:
Pointer to destination ABGR multi-component row. abgr must be 8-byte aligned.
Pointer to source Y component row. y must be 8-byte aligned.
Pointer to source Cb component row. cb must be 8-byte aligned.
Pointer to source Cr component row. cr must be 8-byte aligned.
Length of Y component row. The length of Cb and Cr component rows must be n. The length of the ABGR multi-component row must be 4*n.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_VideoColorJFIFYCC2ARGB444(3MLIB), mlib_VideoColorJFIFYCC2RGB444(3MLIB), mlib_VideoColorJFIFYCC2RGB444_S16(3MLIB), attributes(5)
