cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsFillCircle_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 r, mlib_s32 c);
mlib_status mlib_GraphicsFillCircle_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillCircle_X_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 r, mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsFillCircle_X_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillCircle_A_8(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillCircle_A_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillCircle_B_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 r, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsFillCircle_B_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillCircle_AB_8(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillCircle_AB_32(mlib_image *buffer, mlib_s16 x,
Each of the mlib_GraphicsFillCircle_*() functions draws a filled circle with the center at (x, y) and radius r.
Each of the mlib_GraphicsFillCircle_X_*() functions draws a filled circle in Xor mode as follows:
    data[x,y] ^= c ^ c2
Each of the mlib_GraphicsFillCircle_A_*() functions draws a filled circle with antialiasing.
Each of the mlib_GraphicsFillCircle_B_*() functions draws a filled circle with alpha blending as follows:
    data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Each of the mlib_GraphicsFillCircle_AB_*() functions draws a filled circle with antialiasing and alpha blending.
Each of the functions takes some of the following arguments:
Pointer to the image into which the function is drawing.
X coordinate of the center.
Y coordinate of the center.
Radius of the arc.
Color used in the drawing.
Alternation color.
Alpha value for blending. 0 ≤ a ≤ 255.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_GraphicsFillArc(3MLIB), mlib_GraphicsFillEllipse(3MLIB), attributes(5)
