cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoDCT8x8_S16_S16_B12(
mlib_s16 coeffs[64], const mlib_s16 block[64]);
This function computes the forward DCT for the destination DCT coefficients of data type mlib_s16 and source block of data type mlib_s16. The source to the DCT routine can occupy up to 12 bits for each of its elements.
The source and destination buffer addresses must be 8-byte aligned.
This function can be used in JPEG with 12-bit precision.
The function takes the following arguments:
Pointer to the output DCT coefficients. Note that coeffs must be 8-byte aligned.
Pointer to an 8x8 block. Note that block must be 8-byte aligned.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_VideoDCT2x2_S16_S16(3MLIB), mlib_VideoDCT4x4_S16_S16(3MLIB), mlib_VideoDCT8x8_S16_S16_B10(3MLIB), mlib_VideoDCT8x8_S16_S16_B10_NA(3MLIB), mlib_VideoDCT8x8_S16_U8(3MLIB), mlib_VideoDCT8x8_S16_U8_NA(3MLIB), mlib_VideoDCT16x16_S16_S16(3MLIB), mlib_VideoDCT16x16_S16_S16_B10(3MLIB), attributes(5)
