man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_GraphicsFillTriangleSet_BZ_32(3MLIB)
Name
mlib_GraphicsFillTriangleSet, mlib_GraphicsFillTriangleSet_8, mlib_GraphicsFillTriangleSet_32, mlib_GraphicsFillTriangleSet_X_8, mlib_GraphicsFillTriangleSet_X_32, mlib_GraphicsFillTriangleSet_A_8, mlib_GraphicsFillTriangleSet_A_32, mlib_GraphicsFillTriangleSet_B_8, mlib_GraphicsFillTriangleSet_B_32, mlib_GraphicsFillTriangleSet_G_8, mlib_GraphicsFillTriangleSet_G_32, mlib_GraphicsFillTriangleSet_Z_8, mlib_GraphicsFillTriangleSet_Z_32, mlib_GraphicsFillTriangleSet_AB_8, mlib_GraphicsFillTriangleSet_AB_32, mlib_GraphicsFillTriangleSet_ABG_8, mlib_GraphicsFillTriangleSet_ABG_32, mlib_GraphicsFillTriangleSet_ABGZ_8, mlib_GraphicsFillTriangleSet_ABGZ_32, mlib_GraphicsFillTriangleSet_ABZ_8, mlib_GraphicsFillTriangleSet_ABZ_32, mlib_GraphicsFillTriangleSet_AG_8, mlib_GraphicsFillTriangleSet_AG_32, mlib_GraphicsFillTriangleSet_AGZ_8, mlib_GraphicsFillTriangleSet_AGZ_32, mlib_GraphicsFillTriangleSet_AZ_8, mlib_GraphicsFillTriangleSet_AZ_32, mlib_GraphicsFillTriangleSet_BG_8, mlib_GraphicsFillTriangleSet_BG_32, mlib_GraphicsFillTriangleSet_BGZ_8, mlib_GraphicsFillTriangleSet_BGZ_32, mlib_GraphicsFillTriangleSet_BZ_8, mlib_GraphicsFillTriangleSet_BZ_32, mlib_GraphicsFillTriangleSet_GZ_8, mlib_GraphicsFillTriangleSet_GZ_32 - draw filled triangle set where each member can have different vertices
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsFillTriangleSet_8(mlib_image *buffer,
     const mlib_s16 *x, const mlib_s16 *y, mlib_s32 npoints, mlib_s32 c);
mlib_status mlib_GraphicsFillTriangleSet_32(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_X_8(mlib_image *buffer,
     const mlib_s16 *x, const mlib_s16 *y, mlib_s32 npoints, mlib_s32 c,
     mlib_s32 c2);
mlib_status mlib_GraphicsFillTriangleSet_X_32(mlib_image *buffer,
     mlib_s32 c2);
mlib_status mlib_GraphicsFillTriangleSet_A_8(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_A_32(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_B_8(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsFillTriangleSet_B_32(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsFillTriangleSet_G_8(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsFillTriangleSet_G_32(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsFillTriangleSet_Z_8(mlib_image *buffer,
     mlib_image *zbuffer, const mlib_s16 *x, const mlib_s16 *y,
     const mlib_s16 *z, mlib_s32 npoints, mlib_s32 c);
mlib_status mlib_GraphicsFillTriangleSet_Z_32(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_AB_8(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsFillTriangleSet_AB_32(mlib_image *buffer,
     mlib_s32 a);
mlib_status mlib_GraphicsFillTriangleSet_ABG_8(mlib_image *buffer,
     const mlib_s32 *c, mlib_s32 a);
mlib_status mlib_GraphicsFillTriangleSet_ABG_32(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_ABGZ_8(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, const mlib_s32 *c, mlib_s32 a);
mlib_status mlib_GraphicsFillTriangleSet_ABGZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_ABZ_8(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsFillTriangleSet_ABZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_AG_8(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsFillTriangleSet_AG_32(mlib_image *buffer,
     const mlib_s32 *c);
mlib_status mlib_GraphicsFillTriangleSet_AGZ_8(mlib_image *buffer,
     const mlib_s16 *z, mlib_s32 npoints, const mlib_s32 *c);
mlib_status mlib_GraphicsFillTriangleSet_AGZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_AZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_AZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_BG_8(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_BG_32(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_BGZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_BGZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_BZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_BZ_32(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_GZ_8(mlib_image *buffer,
mlib_status mlib_GraphicsFillTriangleSet_GZ_32(mlib_image *buffer,
Description
Each of the mlib_GraphicsFillTriangleSet_*() functions draws a set of filled triangles with vertices at {(x1,y1), (x2,y2), (x3,y3)}, {(x4,y4), (x5,y5), (x6,y6)}, ..., and {(xn-2,yn-2), (xn-1,yn-1), (xn,yn)}.
Each of the mlib_GraphicsFillTriangleSet_X_*() functions draws a set of filled triangles in Xor mode as follows:
    data[x,y] ^= c ^ c2
Each of the mlib_GraphicsFillTriangleSet_A_*() functions draws a set of filled triangles with antialiasing.
Each of the mlib_GraphicsFillTriangleSet_B_*() functions draws a set of filled triangles with alpha blending as follows:
    data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Each of the mlib_GraphicsFillTriangleSet_G_*() functions draws a set of filled triangles with Gouraud shading.
Each of the mlib_GraphicsFillTriangleSet_Z_*() functions draws a set of filled triangles with Z buffering.
Each of the other functions draws a set of filled triangles with a combination of two or more features like antialiasing (A), alpha blending (B), Gouraud shading (G), and Z buffering (Z).
Parameters
Each of the functions takes some of the following arguments:
buffer
Pointer to the image into which the function is drawing.
zbuffer
Pointer to the image that holds the Z buffer.
x
Pointer to array of X coordinates of the points.
y
Pointer to array of Y coordinates of the points.
z
Pointer to array of Z coordinates of the points.
npoints
Number of points in the arrays. npoints must be a multiple of 3.
c
Color used in the drawing, or pointer to array of colors of the points in the case of Gouraud shading.
c2
Alternation color.
a
Alpha value for blending. 0 ≤ a ≤ 255.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_GraphicsFillTriangle(3MLIB), mlib_GraphicsFillTriangleFanSet(3MLIB), mlib_GraphicsFillTriangleStripSet(3MLIB), attributes(5)
