cc [ flag... ] file... –lmlib [ library... ] #include <mlib.h> mlib_status mlib_VideoH263OverlappedMC_U8_U8(mlib_u8 *curr_block, const mlib_u8 *ref_frame, mlib_s32 mch, mlib_s32 mcv, mlib_s32 mah, mlib_s32 mav, mlib_s32 mbh, mlib_s32 mbv, mlib_s32 mlh, mlib_s32 mlv, mlib_s32 mrh, mlib_s32 mrv, mlib_s32 curr_stride, mlib_s32 ref_stride);
The mlib_VideoH263OverlappedMC_U8_U8() function generates an 8x8 luminance prediction block (motion-compensated block) in the Advanced Prediction Mode for H.263 codec. The reference frame in this function is an interpolated frame.
The following equation is used:
for x = 0, 1, 2, 3; y = 0, 1, 2, 3
curr(x, y) = (ref(2x + mch, 2y + mcv)*H0(x, y) + ref(2x + mah, 2y + mav)*H1(x, y) + ref(2x + mlh, 2y + mlv)*H2(x, y)) / 8;
for x = 4, 5, 6, 7; y = 0, 1, 2, 3
curr(x, y) = (ref(2x + mch, 2y + mcv)*H0(x, y) + ref(2x + mah, 2y + mav)*H1(x, y) + ref(2x + mrh, 2y + mrv)*H2(x, y)) / 8;
for x = 0, 1, 2, 3; y = 4, 5, 6, 7
curr(x, y) = (ref(2x + mch, 2y + mcv)*H0(x, y) + ref(2x + mbh, 2y + mbv)*H1(x, y) + ref(2x + mlh, 2y + mlv)*H2(x, y)) / 8;
for x = 4, 5, 6, 7; y = 4, 5, 6, 7
curr(x, y) = (ref(2x + mch, 2y + mcv)*H0(x, y) + ref(2x + mbh, 2y + mbv)*H1(x, y) + ref(2x + mrh, 2y + mrv)*H2(x, y)) / 8;
where
[ 4 5 5 5 5 5 5 4 ] | 5 5 5 5 5 5 5 5 | | 5 5 6 6 6 6 5 5 | H0 = | 5 5 6 6 6 6 5 5 | | 5 5 6 6 6 6 5 5 | | 5 5 6 6 6 6 5 5 | | 5 5 5 5 5 5 5 5 | [ 4 5 5 5 5 5 5 4 ] [ 2 2 2 2 2 2 2 2 ] | 1 1 2 2 2 2 1 1 | | 1 1 1 1 1 1 1 1 | H1 = | 1 1 1 1 1 1 1 1 | | 1 1 1 1 1 1 1 1 | | 1 1 1 1 1 1 1 1 | | 1 1 2 2 2 2 1 1 | [ 2 2 2 2 2 2 2 2 ] [ 2 1 1 1 1 1 1 2 ] | 2 2 1 1 1 1 2 2 | | 2 2 1 1 1 1 2 2 | H2 = | 2 2 1 1 1 1 2 2 | | 2 2 1 1 1 1 2 2 | | 2 2 1 1 1 1 2 2 | | 2 2 1 1 1 1 2 2 | [ 2 1 1 1 1 1 1 2 ]
The function takes the following arguments:
Pointer to the current block.
Pointer to the interpolated reference frame.
Horizontal coordinate of the motion vector for the current block.
Vertical coordinate of the motion vector for the current block.
Horizontal coordinate of the motion vector for the block above the current block.
Vertical coordinate of the motion vector for the block above the current block.
Horizontal coordinate of the motion vector for the block below the current block.
Vertical coordinate of the motion vector for the block below the current block.
Horizontal coordinate of the motion vector for the block to the left of the current block.
Vertical coordinate of the motion vector for the block to the left of the current block.
Horizontal coordinate of the motion vector for the block to the right of the current block.
Vertical coordinate of the motion vector for the block to the right of the current block.
Stride, in bytes, between adjacent rows in the current frame.
Stride, in bytes, between adjacent rows in the interpolated reference frame.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_VideoAddBlock_U8_S16(3MLIB), mlib_VideoCopyRef_S16_U8(3MLIB), mlib_VideoCopyRef_S16_U8_16x16(3MLIB), mlib_VideoCopyRef_U8_U8_16x16(3MLIB), mlib_VideoCopyRefAve_U8_U8_16x16(3MLIB), mlib_VideoH263OverlappedMC_S16_U8(3MLIB), mlib_VideoInterpAveX_U8_U8(3MLIB), mlib_VideoInterpAveX_U8_U8_16x16(3MLIB), mlib_VideoInterpAveXY_U8_U8(3MLIB), mlib_VideoInterpAveXY_U8_U8_16x16(3MLIB), mlib_VideoInterpAveY_U8_U8(3MLIB), mlib_VideoInterpAveY_U8_U8_16x16(3MLIB), mlib_VideoInterpX_S16_U8(3MLIB), mlib_VideoInterpX_S16_U8_16x16(3MLIB), mlib_VideoInterpX_U8_U8(3MLIB), mlib_VideoInterpXY_S16_U8(3MLIB), mlib_VideoInterpXY_S16_U8_16x16(3MLIB), mlib_VideoInterpXY_U8_U8(3MLIB), mlib_VideoInterpXY_U8_U8_16x16(3MLIB), mlib_VideoInterpY_S16_U8(3MLIB), mlib_VideoInterpY_S16_U8_16x16(3MLIB), mlib_VideoInterpY_U8_U8(3MLIB), mlib_VideoInterpY_U8_U8_16x16(3MLIB), mlib_VideoP64Decimate_U8_U8(3MLIB), mlib_VideoP64Loop_S16_U8(3MLIB), mlib_VideoP64Loop_U8_U8(3MLIB), attributes(5)
