man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_SignalLPCCovariance_S16_Adp(3MLIB)
Name
mlib_SignalLPCCovariance_S16, mlib_SignalLPCCovariance_S16_Adp - perform linear predictive coding with covariance method
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalLPCCovariance_S16(mlib_s16 *coeff,
     mlib_s32 cscale, const mlib_s16 *signal, void *state);
mlib_status mlib_SignalLPCCovariance_S16_Adp(mlib_s16 *coeff,
     mlib_s32 *cscale, const mlib_s16 *signal, void *state);
Description
Each function performs linear predictive coding with covariance method.
In linear predictive coding (LPC) model, each speech sample is represented as a linear combination of the past M samples.
	        M
	s(n) = SUM a(i) * s(n-i) + G * u(n)
	       i=1
where s(*) is the speech signal, u(*) is the excitation signal, and G is the gain constants, M is the order of the linear prediction filter. Given s(*), the goal is to find a set of coefficient a(*) that minimizes the prediction error e(*).
	               M
	e(n) = s(n) - SUM a(i) * s(n-i)
	              i=1
In covariance method, the coefficients can be obtained by solving following set of linear equations.
	 M
	SUM a(i) * c(i,k) = c(0,k), k=1,...,M
	i=1
where
	         N-k-1
	c(i,k) =  SUM s(j) * s(j+k-i)
	          j=0
are the covariance coefficients of s(*), N is the length of the input speech vector.
Note that the covariance matrix R is a symmetric matrix, and the equations can be solved efficiently with Cholesky decomposition method.
See Fundamentals of Speech Recognition by Lawrence Rabiner and Biing-Hwang Juang, Prentice Hall, 1993.
Note for functions with adaptive scaling (with _Adp postfix), the scaling factor of the output data will be calculated based on the actual data; for functions with non-adaptive scaling (without _Adp postfix), the user supplied scaling factor will be used and the output will be saturated if necessary.
Parameters
Each function takes the following arguments:
coeff
The linear prediction coefficients.
cscale
The scaling factor of the linear prediction coefficients, where actual_data = output_data * 2**(-scaling_factor).
signal
The input signal vector with samples in Q15 format.
state
Pointer to the internal state structure.
Return Values
Each function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_SignalLPCCovarianceInit_S16(3MLIB), mlib_SignalLPCCovarianceFree_S16(3MLIB), attributes(5)
