man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_VolumeRayCast_General_Divergent_Trilinear_S16_S16(3MLIB )
Name
mlib_VolumeRayCast_General, mlib_VolumeRayCast_General_Parallel_Nearest_U8_Bit, mlib_VolumeRayCast_General_Parallel_Nearest_U8_U8, mlib_VolumeRayCast_General_Parallel_Nearest_S16_S16, mlib_VolumeRayCast_General_Parallel_Trilinear_U8_U8, mlib_VolumeRayCast_General_Parallel_Trilinear_S16_S16, mlib_VolumeRayCast_General_Divergent_Nearest_U8_Bit, mlib_VolumeRayCast_General_Divergent_Nearest_U8_U8, mlib_VolumeRayCast_General_Divergent_Nearest_S16_S16, mlib_VolumeRayCast_General_Divergent_Trilinear_U8_U8, mlib_VolumeRayCast_General_Divergent_Trilinear_S16_S16 - cast a ray (or rays) through a 3D data set
Synopsis
cc [ flag... ] file... –
lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VolumeRayCast_General_Parallel_Nearest_U8_Bit
     mlib_rays *rays, const mlib_genvolume *
vol, void *buffer);
mlib_status mlib_VolumeRayCast_General_Parallel_Nearest_U8_U8
vol, void *buffer);
mlib_status mlib_VolumeRayCast_General_Parallel_Nearest_S16_S16
vol, void *buffer);
mlib_status mlib_VolumeRayCast_General_Parallel_Trilinear_U8_U8
vol, void *buffer);
mlib_status mlib_VolumeRayCast_General_Parallel_Trilinear_S16_S16
vol, void *buffer);
mlib_status mlib_VolumeRayCast_General_Divergent_Nearest_U8_Bit
vol, void *buffer);
mlib_status mlib_VolumeRayCast_General_Divergent_Nearest_U8_U8
vol, void *buffer);
mlib_status mlib_VolumeRayCast_General_Divergent_Nearest_S16_S16
vol, void *buffer);
mlib_status mlib_VolumeRayCast_General_Divergent_Trilinear_U8_U8
vol, void *buffer);
mlib_status mlib_VolumeRayCast_General_Divergent_Trilinear_S16_S16
vol, void *buffer);
Description
Each of these functions casts a ray (or rays) through a three-dimensional (3D) data set, then computes and returns the interpolated samples at each step along the way.
In trilinear interpolation, the value at point P is computed from its eight surrounding neighbors based on the equation below.
P = (1-a)*(1-b)*(1-c)*P0 +
    a*(1-b)*(1-c)*Px + (1-a)*b*(1-c)*Py + (1-a)*(1-b)*c*Pz +
    a*b*(1-c)*Pxy + a*(1-b)*c*Pxz + (1-a)*b*c*Pyz +
    a*b*c*Pxyz
where a, b, and c are the fractional parts of the coordinates of point P.
The trilinear interpolation is represented by the following figure:
image:Figure that represents the trilinear interpolation
In nearest neighbor operation, the sample value at point P is replaced by the value of the nearest neighbor voxel.
Parameters
Each of the functions takes the following arguments:
rays
Casting rays.
vol
Volume data that consists of slices.
buffer
Working buffer.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_VolumeRayCast_Blocked(3MLIB), attributes(5)
