cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalCepstral_S16_Adp(mlib_s16 *cepst,
     mlib_s32 *cscale, const mlib_s16 *signal, void *state);
The mlib_SignalCepstral_S16_Adp() function performs cepstral analysis. The scaling factor of the output data will be calculated based on the actual data.
The basic operations to compute the cepstrum is shown below.
      |  Fourier  |      |        |       |  Inverse  |
----->|           |----->| log|*| |------>|  Fourier  |----->
 x(n) | Transform | X(k) |        | X'(k) | Transform | c(n)
where x(n) is the input signal and c(n) is its cepstrum. In mathematics, they are
       N-1                2*PI*k*n
X(k) = SUM x(n) * exp(-j*----------)
       n=0                   N
X'(k) = log|X(k)|
        1  N-1                2*PI*k*n
c(n) = --- SUM X'(k) * exp(j*----------)
        N  n=0                   N
Since X'(k) is real and even (symmetric), i.e.
X'(k) = X'(N - k)
the c(n) is real and the equation becomes Cosine transform.
        1  N-1              2*PI*k*n
c(n) = --- SUM X'(k) * cos(----------)
        N  n=0                 N
The cepstral coefficients in LPC is a special case of the above.
See Digital Signal Processing by Alan V. Oppenheim and Ronald W. Schafer, Prentice Hall, 1974.
See Fundamentals of Speech Recognition by Lawrence Rabinerand Biing-Hwang Juang, Prentice Hall, 1993.
The function takes the following arguments:
The cepstral coefficients.
The scaling factor of cepstral coefficients, where actual_data = output_data * 2**(-scaling_factor).
The input signal vector, the signal samples are in Q15 format.
Pointer to the internal state structure.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_SignalCepstralInit_S16(3MLIB), mlib_SignalCepstral_S16(3MLIB), mlib_SignalCepstralFree_S16(3MLIB), attributes(5)
