cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
void mlib_VideoColorBlendABGR_Inp(mlib_u32 *src1dst,
     const mlib_u32 *src2,mlib_s32 src1dst_w,
     mlib_s32 src1dst_h,mlib_s32 src2_w,
     mlib_s32 src2_h,mlib_s32 src2_x,
     mlib_s32 src2_y,mlib_s32 src1dst_lb,
     mlib_s32 src2_lb,mlib_blend src1dst_blend,
     mlib_blend src2_blend);
void mlib_VideoColorBlendABGR_ResetAlpha_Inp(mlib_u32 *src1dst,
     const mlib_u32 *src2, mlib_s32 src1dst_w,
     mlib_s32 src1dst_h, mlib_s32 src2_w,
     mlib_s32 src2_h, mlib_s32 src2_x,
     mlib_s32 src2_y, mlib_s32 src1dst_lb,
     mlib_s32 src2_lb, mlib_blend src1dst_blend,
The functions use the following equation for blending images:
src1dst = (src1dst * src1dst_blend) + (src2 * src2_blend)
The two multi-banded source images (src1dst and src2) are blended together and the result is stored in src1dst. src1dst_blend specifies the blend function to be applied to the src1dst image and src2_blend specifies the blend function to be applied to the src2 image. src2_x and src2_y specify position of src2 relative to the upper-left corner of src1dst. src2 is clipped to the boundaries of src1dst, if needed.
Possible blend functions are:
MLIB_BLEND_ZERO MLIB_BLEND_ONE MLIB_BLEND_SRC_ALPHA MLIB_BLEND_ONE_MINUS_SRC_ALPHA MLIB_BLEND_DST_ALPHA MLIB_BLEND_ONE_MINUS_DST_ALPHA
MLIB_BLEND_DST_ALPHA is the alpha band of image src1 scaled to the range 0 to 1. MLIB_BLEND_SRC_ALPHA is the alpha band of image src2 scaled to the range 0 to 1. The output pixel bands are clamped to the range 0 to 255.
For the mlib_VideoColorBlendABGR_ResetAlpha_Inp() function, the alpha value of every pixel in destination image is set to 0 after blending is complete.
Each of the functions takes the following arguments:
Pointer to 1st input image (also dest. image).
Pointer to 2nd input image.
src1dst image width in pixels.
src1dst image height in rows.
src2 image width in pixels.
src2 image height in rows.
src2 horizontal displacement (in pixels), relative to the upper-left corner of src1dst.
src2 vertical displacement (in rows), relative to the upper-left corner of src1dst.
Linebytes for src1dst image.
Linebytes for src2 image.
Blend function for src1dst image.
Blend function for src2 image.
None.
