cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageZoomTranslate(mlib_image *dst,
     const mlib_image *src, mlib_d64 zoomx, mlib_d64 zoomy,
     mlib_d64 tx, mlib_d64 ty, mlib_filter filter,
     mlib_edge edge);
The mlib_ImageZoomTranslate() function will enlarge or minify the source image by the X and Y zoom factors, with translation. It uses the interpolation method as described by the resampling filter.
It uses the following equation for coordinate mapping:
xd = zoomx*xs + tx yd = zoomy*ys + ty
where a point with coordinates (xs, ys) in the source image is mapped to a point with coordinates (xd, yd) in the destination image.
The data type of the images can be MLIB_BIT, MLIB_BYTE, MLIB_SHORT, MLIB_USHORT, or MLIB_INT.
The width and height of the destination image can be different from the width and height of the source image.
The center of the upper-left corner pixel of an image is located at (0.5, 0.5).
The function takes the following arguments:
Pointer to destination image.
Pointer to source image.
X zoom factor. zoomx > 0.
Y zoom factor. zoomy > 0.
X translation.
Y translation.
Type of resampling filter. It can be one of the following:
MLIB_NEAREST MLIB_BILINEAR MLIB_BICUBIC MLIB_BICUBIC2
Type of edge condition. It can be one of the following:
MLIB_EDGE_DST_NO_WRITE MLIB_EDGE_DST_FILL_ZERO MLIB_EDGE_OP_NEAREST MLIB_EDGE_SRC_EXTEND MLIB_EDGE_SRC_EXTEND_INDEF MLIB_EDGE_SRC_PADDED
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageZoomTranslate_Fp(3MLIB), mlib_ImageAffine(3MLIB), mlib_ImageAffine_Fp(3MLIB), attributes(5)
