cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
void mlib_VideoColorRGBint_to_BGRAint(mlib_u8 *bgra,
const mlib_u8 *rgb, const mlib_u8 *a_array,
mlib_u8 a_const, mlib_s32 w, mlib_s32 h,
mlib_s32 dlb, mlib_s32 slb, mlib_s32 alb);
The interleaved RGB stream and the A values are combined into an interleaved BGRA byte stream.
The alpha values for this function work in the following fashion:
If the a_array pointer is not NULL, the values are taken from there. It has to have the at least 1/3 the dimension of the RGB buffer.
If the a_array pointer is NULL, the alpha values for every pixel are set to a_const.
In other words, this function's inner loop works like this:
bgra[0] = rgb[2]; bgra[1] = rgb[1]; bgra[2] = rgb[0]; bgra[3] = (a_array == NULL) ? a_const : a_array[0];
The function takes the following arguments:
Pointer to the output BGRA buffer.
Pointer to the input RGB buffer.
Pointer to the alpha buffer.
Constant alpha value.
Image width in pixels.
Image height in lines.
Linebytes of the output buffer.
Linebytes of the input buffer.
Linebytes of the alpha buffer.
None.
