cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageResetSubimageStruct(mlib_image *subimg,
const mlib_image *img, mlib_s32 x, mlib_s32 y,
mlib_s32 w, mlib_s32 h);
The mlib_ImageResetSubimageStruct() function resets a sub-image's data structure using parameters supplied by the user.
The mlib_ImageResetSubimageStruct() function returns MLIB_FAILURE if the supplied parameters do not pass the following sanity checks:
subimg != NULL
img != NULL
0 < w ≤ mlib_ImageGetWidth(img)
0 < h ≤ mlib_ImageGetHeight(img)
0 ≤ x ≤ (mlib_ImageGetWidth(img) - w)
0 ≤ y ≤ (mlib_ImageGetHeight(img) - h)
Whenever MLIB_FAILURE is returned, the original image data structure is not changed.
If mlib_ImageIsUserAllocated(subimg)==0, the original data buffer is freed, otherwise the original data buffer is not freed.
The function takes the following arguments:
Pointer to the sub-image data structure.
Pointer to the source image data structure.
X coordinate of the left border in the source image.
Y coordinate of the top border in the source image.
Width of the sub-image.
Height of the sub-image.
MLIB_SUCCESS is returned if the image data structure is reset successfully. MLIB_FAILURE is returned when the image data structure can not be reset according to the parameters supplied.
mlib_ImageCreate(3MLIB), mlib_ImageCreateSubimage(3MLIB), mlib_ImageCreateStruct(3MLIB), mlib_ImageSetStruct(3MLIB), mlib_ImageResetStruct(3MLIB), mlib_ImageSetSubimageStruct(3MLIB), mlib_ImageDelete(3MLIB), mlib_ImageSetFormat(3MLIB), mlib_ImageSetPaddings(3MLIB), attributes(5)
