cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalLPCAutoCorrelInit_S16(void *state,
mlib_s32 length, mlib_s32 order);
mlib_status mlib_SignalLPCAutoCorrelInit_F32(void *state,
Each function initializes the internal state structure for autocorrelation method of linear predictive coding (LPC).
The init function performs internal state structure allocation and global initialization. Per LPC function call initialization is done in LPC function, so the same internal state structure can be reused for multiple LPC function calls.
Each function takes the following arguments:
Pointer to the internal state structure.
The length of the input signal vector.
The order of the linear prediction filter.
Each function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_SignalLPCAutoCorrel_S16(3MLIB), mlib_SignalLPCAutoCorrelGetEnergy_S16(3MLIB), mlib_SignalLPCAutoCorrelGetPARCOR_S16(3MLIB), mlib_SignalLPCAutoCorrelFree_S16(3MLIB), attributes(5)
