cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalMulWindow_F32S_F32S(mlib_f32 *dst,
const mlib_f32 *src, const mlib_f32 *window, mlib_s32 n);
The mlib_SignalMulWindow_F32S_F32S() function performs a windowing operation.
The function takes the following arguments:
Output signal array is in stereo format where dst[0] contains the values for channel 0, and dst[1] holds the valuesfor channel 1.
Input signal array is in stereo format where src[0] contains the values for channel 0, and src[1] holds the valuesfor channel 1.
Window coefficient array. The window coefficients are in Q15 format.
Number of samples in signal and window arrays.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
