cc [ flag... ] file... –lmlib [ library... ] #include <mlib.h> mlib_status mlib_SignalIFFTW_2_S16_S16_Mod(mlib_s16 *dstr, mlib_s16 *dsti, const mlib_s16 *srcr, const mlib_s16 *srci, const mlib_s16 *window, mlib_s32 order);
mlib_status mlib_SignalIFFTW_2_S16C_S16C_Mod(mlib_s16 *dstc, const mlib_s16 *srcc, const mlib_s16 *window, mlib_s32 order);
mlib_status mlib_SignalIFFTW_2_S16_S16C_Mod(mlib_s16 *dstr, const mlib_s16 *srcc, const mlib_s16 *window, mlib_s32 order);
mlib_status mlib_SignalIFFTW_2_S16_Mod(mlib_s16 *srcdstr, mlib_s16 *srcdsti, const mlib_s16 *window, mlib_s32 order);
mlib_status mlib_SignalIFFTW_2_S16C_Mod(mlib_s16 *srcdstc, const mlib_s16 *window, mlib_s32 order);
mlib_status mlib_SignalIFFTW_2_F32_F32(mlib_f32 *dstr, mlib_f32 *dsti, const mlib_f32 *srcr, const mlib_f32 *srci, const mlib_f32 *window, mlib_s32 order);
mlib_status mlib_SignalIFFTW_2_F32C_F32C(mlib_f32 *dstc, const mlib_f32 *srcc, const mlib_f32 *window, mlib_s32 order);
mlib_status mlib_SignalIFFTW_2_F32_F32C(mlib_f32 *dstr, const mlib_f32 *srcc, const mlib_f32 *window, mlib_s32 order);
mlib_status mlib_SignalIFFTW_2_F32(mlib_f32 *srcdstr, mlib_f32 *srcdsti, const mlib_f32 *window, mlib_s32 order);
mlib_status mlib_SignalIFFTW_2_F32C(mlib_f32 *srcdstc, const mlib_f32 *window, mlib_s32 order);
Each of the functions in this group performs Inverse Fast Fourier Transform with windowing (IFFTW).
The FFTW functions use the following equation:
1 N-1 dst[k] = ---- SUM {src[n] * window[n] * exp(-j2*PI*n*k/N)} C1 n=0
and the IFFTW functions use the following equation:
1 N-1 dst[n] = ---- SUM {src[k] * window[k] * exp(j2*PI*n*k/N)} C2 k=0
where
k = 0, 1, ..., (N - 1) n = 0, 1, ..., (N - 1) N = 2**order
The signal FFTW/IFFTW functions can be categorized into four groups according to the ScaleMode in the function names in the following form:
mlib_Signal[FFTW|IFFTW]_ScaleMode_OutType_InType_OpMode() mlib_Signal[FFTW|IFFTW]_ScaleMode_DataType_OpMode()
The scaling factors C1 and C2 used in the equations are defined as follows:
For ScaleMode = 1, C1 = 1 and C2 = 2**order.
For ScaleMode = 2, C1 = 2**order and C2 = 1.
For ScaleMode = 3, C1 = C2 = 2**(order/2) when order is even, or C1 = 2**((order+1)/2) and C2 = 2**((order-1)/2) when order is odd.
For ScaleMode = 4, C1 = 2**P and C2 = 2**Q, where P and Q are adaptive scaling factors and are generated by the functions.
For functions with only real parts for the source signal, the imaginary parts are assumed to be all zero. For functions with only real parts for the destination signal, the imaginary parts are discarded. The functions with only one data type in their names perform the operation in place.
Each function takes some of the following arguments:
Destination signal array that contains the real parts.
Destination signal array that contains the imaginary parts.
Source signal array that contains the real parts.
Source signal array that contains the imaginary parts.
Complex destination signal array. dstc[2*i] contains the real parts, and dstc[2*i+1] contains the imaginary parts.
Complex source signal array. srcc[2*i] contains the real parts, and srcc[2*i+1] contains the imaginary parts.
Source and destination signal array that contains the real parts.
Source and destination signal array that contains the imaginary parts.
Complex source and destination signal array. srcdstc[2*i] contains the real parts, and srcdstc[2*i+1] contains the imaginary parts.
Window coefficient array with 2**order real elements. The window coefficients are in Q15 format for the S16 data type, or in float format for the F32 data type.
Order of the transformation. The base-2 logarithm of the number of data samples.
Each function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_SignalFFTW_1(3MLIB), mlib_SignalFFTW_2(3MLIB), mlib_SignalFFTW_3(3MLIB), mlib_SignalFFTW_4(3MLIB), mlib_SignalIFFTW_1(3MLIB), mlib_SignalIFFTW_3(3MLIB), mlib_SignalIFFTW_4(3MLIB), attributes(5)
