man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_MatrixMulShift_S16_S16_Mod (3MLIB)
Name
mlib_MatrixMulShift_S16_S16_Mod, mlib_MatrixMulShift_S16_S16_Sat, mlib_MatrixMulShift_S16C_S16C_Mod, mlib_MatrixMulShift_S16C_S16C_Sat - matrix multiplication plus shifting
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_MatrixMulShift_S16_S16_Mod(mlib_s16 *z,
    const mlib_s16 *x, const mlib_s16 *y, mlib_s32 m,
    mlib_s32 l, mlib_s32 n, mlib_s32 shift);
mlib_status mlib_MatrixMulShift_S16_S16_Sat(mlib_s16 *z,
mlib_status mlib_MatrixMulShift_S16C_S16C_Mod(mlib_s16 *z,
mlib_status mlib_MatrixMulShift_S16C_S16C_Sat(mlib_s16 *z,
Description
Each of these functions performs a multiplication of two matrices and shifts the result.
For real data, the following equation is used:
              l-1
z[i*n + j] = {SUM (x[i*l + k] * y[k*n + j])} * 2**(-shift)
              k=0
where i = 0, 1, ..., (m - 1); j = 0, 1, ..., (n - 1).
For complex data, the following equation is used:
                      l-1
z[2*(i*n + j)]     = {SUM (xR*yR - xI*yI)} * 2**(-shift)
                      k=0
                      l-1
z[2*(i*n + j) + 1] = {SUM (xR*yI + xI*yR)} * 2**(-shift)
                      k=0
where
xR = x[2*(i*l + k)]
xI = x[2*(i*l + k) + 1]
yR = y[2*(k*n + j)]
yI = y[2*(k*n + j) + 1]
Parameters
Each of the functions takes the following arguments:
z
Pointer to the first element of the result matrix, in row major order.
x
Pointer to the first element of the first matrix, in row major order.
y
Pointer to the first element of the second matrix, in row major order.
m
Number of rows in the first matrix. m > 0.
l
Number of columns in the first matrix, and the number of rows in the second matrix. l > 0.
n
Number of columns in the second matrix. n > 0.
shift
Right shifting factor. 1 ≤ shift ≤ 16.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_MatrixMul_U8_U8_Mod(3MLIB), attributes(5)
