cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoDCT16x16_S16_S16_B10(mlib_s16 coeffs[256],
const mlib_s16 block[256]);
The mlib_VideoDCT16x16_S16_S16_B10() function computes the forward DCT for the destination DCT coefficients of data type mlib_s16 and source block of data type mlib_s16. The input to the DCT routine is the difference between the current block and the reference block. The difference pixel which can occupy 10 bits, is represented as a 16-bit data.
The function takes the following arguments:
Pointer to the output DCT coefficients. Note that coeffs must be 8-byte aligned.
Pointer to a 16x16 motion-compensated block which is the difference between the reference block and the current block. Note that block must be 8-byte aligned.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_VideoDCT2x2_S16_S16(3MLIB), mlib_VideoDCT4x4_S16_S16(3MLIB), mlib_VideoDCT8x8_S16_S16(3MLIB), mlib_VideoDCT8x8_S16_S16_B12(3MLIB), mlib_VideoDCT8x8_S16_S16_NA(3MLIB), mlib_VideoDCT8x8_S16_U8(3MLIB), mlib_VideoDCT8x8_S16_U8_NA(3MLIB), mlib_VideoDCT16x16_S16_S16(3MLIB), mlib_VideoDeQuantize_S16(3MLIB), mlib_VideoDeQuantizeInit_S16(3MLIB), mlib_VideoQuantize_S16(3MLIB), mlib_VideoQuantizeInit_S16(3MLIB), attributes(5)
