man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_SignalFFTW_4_S16(3MLIB)
Name
mlib_SignalFFTW_4, mlib_SignalFFTW_4_S16_S16, mlib_SignalFFTW_4_S16C_S16C, mlib_SignalFFTW_4_S16C_S16, mlib_SignalFFTW_4_S16, mlib_SignalFFTW_4_S16C - signal Fast Fourier Transform with windowing (FFTW)
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalFFTW_4_S16_S16(mlib_s16 *dstr, mlib_s16 *dsti,
     const mlib_s16 *srcr, const mlib_s16 *srci, const mlib_s16 *window,
     mlib_s32 order, mlib_s32 *scale);
mlib_status mlib_SignalFFTW_4_S16C_S16C(mlib_s16 *dstc,
     const mlib_s16 *srcc,const mlib_s16 *window, mlib_s32 order,
     mlib_s32 *scale);
mlib_status mlib_SignalFFTW_4_S16C_S16(mlib_s16 *dstc,
     const mlib_s16 *srcr,const mlib_s16 *window, mlib_s32 order,
     mlib_s32 *scale);
mlib_status mlib_SignalFFTW_4_S16(mlib_s16 *srcdstr,
     mlib_s16 *srcdsti,const mlib_s16 *window, mlib_s32 order,
     mlib_s32 *scale);
mlib_status mlib_SignalFFTW_4_S16C(mlib_s16 *srcdstc,
     const mlib_s16 *window,mlib_s32 order, mlib_s32 *scale);
Description
Each of the functions in this group performs Fast Fourier Transform with windowing (FFTW).
The FFTW functions use the following equation:
          1   N-1
dst[k] = ---- SUM {src[n] * window[n] * exp(-j2*PI*n*k/N)}
          C1  n=0
and the IFFTW functions use the following equation:
          1   N-1
dst[n] = ---- SUM {src[k] * window[k] * exp(j2*PI*n*k/N)}
          C2  k=0
where
k = 0, 1, ..., (N - 1)
n = 0, 1, ..., (N - 1)
N = 2**order
The signal FFTW/IFFTW functions can be categorized into four groups according to the ScaleMode in the function names in the following form:
mlib_Signal[FFTW|IFFTW]_ScaleMode_OutType_InType_OpMode()
mlib_Signal[FFTW|IFFTW]_ScaleMode_DataType_OpMode()
The scaling factors C1 and C2 used in the equations are defined as follows:
  • For ScaleMode = 1, C1 = 1 and C2 = 2**order.
  • For ScaleMode = 2, C1 = 2**order and C2 = 1.
  • For ScaleMode = 3, C1 = C2 = 2**(order/2) when order is even, or C1 = 2**((order+1)/2) and C2 = 2**((order-1)/2) when order is odd.
  • For ScaleMode = 4, C1 = 2**P and C2 = 2**Q, where P and Q are adaptive scaling factors and are generated by the functions.
For functions with only real parts for the source signal, the imaginary parts are assumed to be all zero. For functions with only real parts for the destination signal, the imaginary parts are discarded. The functions with only one data type in their names perform the operation in place.
Parameters
Each function takes some of the following arguments:
dstr
Destination signal array that contains the real parts.
dsti
Destination signal array that contains the imaginary parts.
srcr
Source signal array that contains the real parts.
srci
Source signal array that contains the imaginary parts.
dstc
Complex destination signal array. dstc[2*i] contains the real parts, and dstc[2*i+1] contains the imaginary parts.
srcc
Complex source signal array. srcc[2*i] contains the real parts, and srcc[2*i+1] contains the imaginary parts.
srcdstr
Source and destination signal array that contains the real parts.
srcdsti
Source and destination signal array that contains the imaginary parts.
srcdstc
Complex source and destination signal array. srcdstc[2*i] contains the real parts, and srcdstc[2*i+1] contains the imaginary parts.
window
Window coefficient array with 2**order real elements. The window coefficients are in Q15 format for the S16 data type, or in float format for the F32 data type.
order
Order of the transformation. The base-2 logarithm of the number of data samples.
scale
Adaptive scaling factor.
Return Values
Each function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_SignalFFTW_1(3MLIB), mlib_SignalFFTW_2(3MLIB), mlib_SignalFFTW_3(3MLIB), mlib_SignalIFFTW_1(3MLIB), mlib_SignalIFFTW_2(3MLIB), mlib_SignalIFFTW_3(3MLIB), mlib_SignalIFFTW_4(3MLIB), attributes(5)
