man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_VectorMulMShift_S16C_S16C_Sat(3MLIB)
Name
mlib_VectorMulMShift_S16_S16_Mod, mlib_VectorMulMShift_S16_S16_Sat, mlib_VectorMulMShift_S16C_S16C_Mod, mlib_VectorMulMShift_S16C_S16C_Sat - multiplication of vector by matrix with shifting
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VectorMulMShift_S16_S16_Mod(mlib_s16 *z,
     const mlib_s16 *x, const mlib_s16 *y, mlib_s32 m,
     mlib_s32 n, mlib_s32 shift);
mlib_status mlib_VectorMulMShift_S16_S16_Sat(mlib_s16 *z,
mlib_status mlib_VectorMulMShift_S16C_S16C_Mod(mlib_s16 *z,
mlib_status mlib_VectorMulMShift_S16C_S16C_Sat(mlib_s16 *z,
Description
Each of these functions multiplies a vector by a matrix and shifts the results.
For real data, the following equation is used:
         m-1
z[i] = { SUM (x[j] * y[j*m + i]) } * 2**(-shift)
         j=0
where i = 0, 1, ..., (n - 1).
For complex data, the following equation is used:
               m-1
z[2*i ]    = { SUM (xR*yR - xI*yI) } * 2**(-shift)
               j=0
               m-1
z[2*i + 1] = { SUM (xR*yI + xI*yR) } * 2**(-shift)
               j=0
where i = 0, 1, ..., (n - 1), and
xR = x[2*j]
xI = x[2*j + 1]
yR = y[2*(j*m + i)]
yI = y[2*(j*m + i) + 1]
Parameters
Each of the functions takes the following arguments:
z
Pointer to the first element of the destination vector.
x
Pointer to the first element of the source vector.
y
Pointer to the first element of the source matrix.
m
Number of rows in the matrix, and number of elements in the source vector.
n
Number of columns in the matrix, and number of elements in the destination vector.
shift
Right shifting factor.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_VectorMulM_U8_U8_Mod(3MLIB), attributes (5)
