man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_GraphicsDrawCircle_32 (3MLIB)
Name
mlib_GraphicsDrawCircle, mlib_GraphicsDrawCircle_8, mlib_GraphicsDrawCircle_32, mlib_GraphicsDrawCircle_X_8, mlib_GraphicsDrawCircle_X_32, mlib_GraphicsDrawCircle_A_8, mlib_GraphicsDrawCircle_A_32, mlib_GraphicsDrawCircle_B_8, mlib_GraphicsDrawCircle_B_32, mlib_GraphicsDrawCircle_AB_8, mlib_GraphicsDrawCircle_AB_32 - draw circle
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsDrawCircle_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 r, mlib_s32 c);
mlib_status mlib_GraphicsDrawCircle_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawCircle_X_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 r, mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsDrawCircle_X_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawCircle_A_8(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawCircle_A_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawCircle_B_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 r, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsDrawCircle_B_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawCircle_AB_8(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawCircle_AB_32(mlib_image *buffer, mlib_s16 x,
Description
Each of the mlib_GraphicsDrawCircle_*() functions draws a circle with the center at (x, y) and radius r.
Each of the mlib_GraphicsDrawCircle_X_*() functions draws a circle in Xor mode as follows:
    data[x,y] ^= c ^ c2
Each of the mlib_GraphicsDrawCircle_A_*() functions draws a circle with antialiasing.
Each of the mlib_GraphicsDrawCircle_B_*() functions draws a circle with alpha blending as follows:
    data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Each of the mlib_GraphicsDrawCircle_AB_*() functions draws a circle with antialiasing and alpha blending.
Parameters
Each of the functions takes some of the following arguments:
buffer
Pointer to the image into which the function is drawing.
x
X coordinate of the center.
y
Y coordinate of the center.
r
Radius of the arc.
c
Color used in the drawing.
c2
Alternation color.
a
Alpha value for blending. 0 ≤ a ≤ 255.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_GraphicsDrawArc(3MLIB), mlib_GraphicsDrawEllipse(3MLIB), attributes(5)
