man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_GraphicsDrawRectangle_X_32(3MLIB)
Name
mlib_GraphicsDrawRectangle, mlib_GraphicsDrawRectangle_8, mlib_GraphicsDrawRectangle_32, mlib_GraphicsDrawRectangle_X_8, mlib_GraphicsDrawRectangle_X_32, mlib_GraphicsDrawRectangle_B_8, mlib_GraphicsDrawRectangle_B_32 - draw rectangle
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsDrawRectangle_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 w, mlib_s32 h, mlib_s32 c);
mlib_status mlib_GraphicsDrawRectangle_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsDrawRectangle_X_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 w, mlib_s32 h, mlib_s32 c, mlib_s32 c2);
mlib_status mlib_GraphicsDrawRectangle_X_32(mlib_image *buffer,
     mlib_s16 x, mlib_s16 y, mlib_s32 w, mlib_s32 h, mlib_s32 c,
     mlib_s32 c2);
mlib_status mlib_GraphicsDrawRectangle_B_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 w, mlib_s32 h, mlib_s32 c, mlib_s32 a);
mlib_status mlib_GraphicsDrawRectangle_B_32(mlib_image *buffer,
     mlib_s32 a);
Description
Each of the mlib_GraphicsDrawRectangle_*() functions draws a rectangle with the upper-left corner at (x, y), width w, and height h.
Each of the mlib_GraphicsDrawRectangle_X_*() functions draws a rectangle in Xor mode as follows:
    data[x,y] ^= c ^ c2
Each of the mlib_GraphicsDrawRectangle_B_*() functions draws a rectangle with alpha blending as follows:
    data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Parameters
Each of the functions takes some of the following arguments:
buffer
Pointer to the image into which the function is drawing.
x
X coordinate of the upper-left corner of the rectangle.
y
Y coordinate of the upper-left corner of the rectangle.
w
Width of the rectangle.
h
Height of the rectangle.
c
Color used in the drawing.
c2
Alternation color.
a
Alpha value for blending. 0 ≤ a ≤ 255.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_GraphicsFillRectangle(3MLIB), attributes (5)
