cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoColorABGR2JFIFYCC420(mlib_u8 *y0,
mlib_u8 *y1, mlib_u8 *cb, mlib_u8 *cr, const mlib_u8 *abgr0,
const mlib_u8 *abgr1, mlib_s32 n);
The mlib_VideoColorABGR2JFIFYCC420() function performs color space conversion from ABGR to YCbCr together with sampling rate conversion when used in the JPEG File Interchange Format (JFIF).
The function takes the following arguments:
Pointer to upper destination Y component row. y0 must be 8-byte aligned.
Pointer to lower destination Y component row. y1 must be 8-byte aligned.
Pointer to destination Cb component row. cb must be 8-byte aligned.
Pointer to destination Cr component row. cr must be 8-byte aligned.
Pointer to upper source ABGR multi-component row. abgr0 must be 8-byte aligned.
Pointer to lower source ABGR multi-component row. abgr1 must be 8-byte aligned.
Length of Y component row. n must be even. The length of Cb and Cr component rows must be n/2. The length of the ABGR multi-component row must be 4*n.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_VideoColorABGR2JFIFYCC422(3MLIB), mlib_VideoColorARGB2JFIFYCC420(3MLIB), mlib_VideoColorARGB2JFIFYCC422(3MLIB), mlib_VideoColorRGB2JFIFYCC420(3MLIB), mlib_VideoColorRGB2JFIFYCC422(3MLIB), attributes(5)
