man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_GraphicsFillEllipse_B_32(3MLIB)
Name
mlib_GraphicsFillEllipse, mlib_GraphicsFillEllipse_8, mlib_GraphicsFillEllipse_32, mlib_GraphicsFillEllipse_X_8, mlib_GraphicsFillEllipse_X_32, mlib_GraphicsFillEllipse_A_8, mlib_GraphicsFillEllipse_A_32, mlib_GraphicsFillEllipse_B_8, mlib_GraphicsFillEllipse_B_32, mlib_GraphicsFillEllipse_AB_8, mlib_GraphicsFillEllipse_AB_32 - draw filled ellipse
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsFillEllipse_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c);
mlib_status mlib_GraphicsFillEllipse_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillEllipse_X_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 a, mlib_s32 b, mlib_f32 t, mlib_s32 c,
     mlib_s32 c2);
mlib_status mlib_GraphicsFillEllipse_X_32(mlib_image *buffer, mlib_s16 x,
     mlib_s32 c2);
mlib_status mlib_GraphicsFillEllipse_A_8(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillEllipse_A_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillEllipse_B_8(mlib_image *buffer, mlib_s16 x,
     mlib_s32 alpha);
mlib_status mlib_GraphicsFillEllipse_B_32(mlib_image *buffer, mlib_s16 x,
     mlib_s32 alpha);
mlib_status mlib_GraphicsFillEllipse_AB_8(mlib_image *buffer, mlib_s16 x,
     mlib_s32 alpha);
mlib_status mlib_GraphicsFillEllipse_AB_32(mlib_image *buffer, mlib_s16 x,
     mlib_s32 alpha);
Description
Each of the mlib_GraphicsFillEllipse_*() functions draws a filled ellipse with the center at (x, y), major semiaxis a, and minor semiaxis b. The angle of the major semiaxis is t counterclockwise from the X axis.
Each of the mlib_GraphicsFillEllipse_X_*() functions draws a filled ellipse in Xor mode as follows:
    data[x,y] ^= c ^ c2
Each of the mlib_GraphicsFillEllipse_A_*() functions draws a filled ellipse with antialiasing.
Each of the mlib_GraphicsFillEllipse_B_*() functions draws a filled ellipse with alpha blending as follows:
    data[x,y] = (data[x,y] * (255 - alpha) + c * alpha) / 255
Each of the mlib_GraphicsFillEllipse_A_*() functions draws a filled ellipse with antialiasing and alpha blending.
Parameters
Each of the functions takes some of the following arguments:
buffer
Pointer to the image into which the function is drawing.
x
X coordinate of the center.
y
Y coordinate of the center.
a
Major semiaxis of the ellipse.
b
Minor semiaxis of the ellipse.
t
Angle of major semiaxis in radians.
c
Color used in the drawing.
c2
Alternation color.
alpha
Alpha value for blending. 0 ≤ alpha ≤ 255.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_GraphicsFillArc(3MLIB), mlib_GraphicsFillCircle(3MLIB), attributes(5)
