cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoDCT8x8_S16_S16_B10(
     mlib_s16 coeffs[64], const mlib_s16 block[64]);
mlib_status mlib_VideoDCT8x8_S16_S16(
The mlib_VideoDCT8x8_S16_S16_B10() function computes the forward DCT for the destination DCT coefficients of data type mlib_s16 and a source block of data type mlib_s16. The input to the DCT routine is the difference between the current block and the reference block. The difference pixel can occupy nine bits and is represented as a 16-bit datum.
The source and destination buffer addresses must be 8-byte aligned.
Since mediaLib 2.5, mlib_VideoDCT8x8_S16_S16() has been renamed to mlib_VideoDCT8x8_S16_S16_B10(). Now mlib_VideoDCT8x8_S16_S16() is an alias of mlib_VideoDCT8x8_S16_S16_B10().
The function takes the following arguments:
Pointer to the destination DCT coefficients. coeffs must be 8-byte aligned.
Pointer to an 8x8 motion-compensated block that is the difference between the reference block and the current block. block must be 8-byte aligned.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_VideoDCT2x2_S16_S16(3MLIB), mlib_VideoDCT4x4_S16_S16(3MLIB), mlib_VideoDCT8x8_S16_S16_B10_NA(3MLIB), mlib_VideoDCT8x8_S16_S16_B12(3MLIB), mlib_VideoDCT8x8_S16_U8(3MLIB), mlib_VideoDCT8x8_S16_U8_NA(3MLIB), mlib_VideoDCT16x16_S16_S16(3MLIB), mlib_VideoDCT16x16_S16_S16_B10(3MLIB), attributes(5)
