cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoUpSample420(mlib_u8 *dst0, mlib_u8 *dst1,
     const mlib_u8 *src0, const mlib_u8 *src1,
     const mlib_u8 *src2, mlib_s32 n);
The mlib_VideoUpSample420() function performs up sampling rate conversion used in JPEG File Interchange Format (JFIF).
The function takes the following arguments:
Pointer to upper destination row. dst0 must be 8-byte aligned.
Pointer to lower destination row. dst1 must be 8-byte aligned.
Pointer to upper source row. src0 must be 8-byte aligned.
Pointer to middle source row. src1 must be 8-byte aligned.
Pointer to lower source row. src2 must be 8-byte aligned.
Length of source rows. n must be greater than 1.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_VideoDownSample420(3MLIB), mlib_VideoDownSample420_S16(3MLIB), mlib_VideoDownSample422(3MLIB), mlib_VideoDownSample422_S16(3MLIB), mlib_VideoUpSample420_Nearest(3MLIB), mlib_VideoUpSample420_Nearest_S16(3MLIB), mlib_VideoUpSample420_S16(3MLIB), mlib_VideoUpSample422(3MLIB), mlib_VideoUpSample422_S16(3MLIB), mlib_VideoUpSample422_Nearest(3MLIB), mlib_VideoUpSample422_Nearest_S16(3MLIB), attributes(5)
