man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_SignalAutoCorrel_F32S (3MLIB)
Name
mlib_SignalAutoCorrel_S16, mlib_SignalAutoCorrel_S16S, mlib_SignalAutoCorrel_F32, mlib_SignalAutoCorrel_F32S - signal auto-correlation
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_SignalAutoCorrel_S16(mlib_d64 *correl,
     const mlib_s16 *src, mlib_s32 disp, mlib_s32 n);
mlib_status mlib_SignalAutoCorrel_S16S(mlib_d64 *correl,
mlib_status mlib_SignalAutoCorrel_F32(mlib_d64 *correl,
     const mlib_f32 *src, mlib_s32 disp, mlib_s32 n);
mlib_status mlib_SignalAutoCorrel_F32S(mlib_d64 *correl,
Description
Each of these functions performs auto-correlation.
For monaural signals, the following equation is used:
              1    n-d-1
correl[0] = ----- * SUM (src[i] * src[i + d])
            n - d   i=0
For stereo signals, the following equation is used:
              1    n-d-1
correl[0] = ----- * SUM (src[2*i] * src[2*(i + d)])
            n - d   i=0
              1    n-d-1
correl[1] = ----- * SUM (src[2*i + 1] * src[2*(i + d) + 1])
            n - d   i=0
where d = disp.
Parameters
Each of the functions takes the following arguments:
correl
Pointer to the auto-correlation array. In the stereo version, correl[0] contains the auto-correlation of channel 0, and correl[1] contains the auto-correlation of channel 1.
src
Source signal array.
disp
Displacement. 0 ≤ disp < n.
n
Number of samples in the source signal array.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_SignalCrossCorrel_S16(3MLIB), attributes(5)
