cc [ flag... ] file... –lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageExtremaLocations( mlib_s32 *min, mlib_s32 *max, const mlib_image *img, mlib_s32 xStart, mlib_s32 yStart, mlib_s32 xPeriod, mlib_s32 yPeriod, mlib_s32 saveLocations, mlib_s32 maxRuns, mlib_s32 *minCounts, mlib_s32 *maxCounts, mlib_s32 **minLocations, mlib_s32 **maxLocations, mlib_s32 len);
mlib_status mlib_ImageExtremaLocations_Fp( mlib_d64 *min, mlib_d64 *max, const mlib_image *img, mlib_s32 xStart, mlib_s32 yStart, mlib_s32 xPeriod, mlib_s32 yPeriod, mlib_s32 saveLocations, mlib_s32 maxRuns, mlib_s32 *minCounts, mlib_s32 *maxCounts, mlib_s32 **minLocations, mlib_s32 **maxLocations, mlib_s32 len);
Each of the functions finds the image-wise minimum and maximum pixel values for each channel, and optionally, their locations.
Each of the functions scans an image, finds the minimum and maximum pixel values for each channel, and finds the locations of those pixels with the minimum or maximum values.
The user provides initial minimum/maximum values through the arguments min and max. This function will update them based on findings.
The set of pixels scanned may furthermore be reduced by specifying xPeriod and yPeriod parameters that specify the sampling rate along each axis.
The set of pixels to be scanned may be obtained from the following equation:
x = xStart + p*xPeriod; 0 ≤ p < (w - xStart)/xPeriod y = yStart + q*yPeriod; 0 ≤ q < (h - yStart)/yPeriod
The locations of the minimum/maximum, if asked, are recorded in a format of run-length coding. Each run-length code, or simply called a run, has a format of (xStart, yStart, length). Here length is defined on the low-resolution image (with downsampling factors of 1/xPeriod, 1/yPeriod) and does not cross rows. So the run-length code (xStart, yStart, length) means that the pixels at (xStart, yStart), (xStart + xPeriod, yStart), ..., (xStart + (length - 1)*xPeriod, yStart) of the original image have a value of the minimum/maximum.
The buffers for minLocations and maxLocations are organized in the following format for each channel i:
minLocations[i][0] = xStart0; // the 1st run minLocations[i][1] = yStart0; minLocations[i][2] = length0; minLocations[i][3] = xStart1; // the 2nd run minLocations[i][4] = yStart1; minLocations[i][5] = length1; ...... // more runs minLocations[i][len-1] = ...;
It is the user's responsibility to allocate enough memory for the buffers for minLocations and maxLocations. This function may return MLIB_OUTOFRANGE, if any of the buffers is not big enough.
The function takes the following arguments:
Pointer to the minimum values.
Pointer to the maximum values.
Pointer to the input image.
Initial X sample coordinate.
Initial Y sample coordinate.
X sampling rate. xPeriod ≥ 1.
Y sampling rate. yPeriod ≥ 1.
If true (i.e., saveLocations != 0), find the extrema locations; otherwise only find the extrema.
Number of runs of the minimum/maximum the caller expects for each channel. maxRuns ≥ 1. If it is MLIB_S32_MAX, all the minimum/maximum locations should be recorded.
Pointer to the numbers of runs of the minimum recorded in minLocations.
Pointer to the numbers of runs of the maximum recorded in maxLocations.
Pointer to the minimum locations in a format of run-length coding.
Pointer to the maximum locations in a format of run-length coding.
Length of the buffers for the minimum/maximum locations in each channel.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageExtrema2(3MLIB), mlib_ImageMaximum(3MLIB), mlib_ImageMaximum_Fp(3MLIB), mlib_ImageMinimum(3MLIB), mlib_ImageMinimum_Fp(3MLIB), attributes(5)
