cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageColorDitherInit(void **colormap, const mlib_s32 *dimensions,
mlib_type intype, mlib_type outtype, mlib_s32 channels, mlib_s32 entries,
mlib_s32 offset, void **lut);
The mlib_ImageColorDitherInit() function creates an internal data structure, colormap, which can be used by one of the following functions for image dithering:
mlib_ImageColorErrorDiffusion3x3 mlib_ImageColorErrorDiffusionMxN mlib_ImageColorOrderedDither8x8 mlib_ImageColorOrderedDitherMxN
The lut might have either 1 or 3 channels. The type of the lut can be one of the following:
MLIB_BYTE in, MLIB_BYTE out (i.e., BYTE-to-BYTE) MLIB_BIT in, MLIB_BYTE out (i.e., BIT-to-BYTE)
If dimensions == NULL, then no colorcube will be created. In this case, the user-provided lookup table, lut, will be used for dithering.
If dimensions != NULL, then a colorcube is created from scratch in a way shown in the following example.
To dither an RGB image of type MLIB_BYTE to a color-indexed image of type MLIB_BYTE, we can use the following parameters:
mlib_s32 dimensions[] = {2, 3, 4};
mlib_type intype = MLIB_BYTE;
mlib_type outtype = MLIB_BYTE;
mlib_s32 channels = 3;
mlib_s32 offset = 6;
These values would lead to the creation of a colorcube that would dither red values in the source image to one of 2 red levels, green values to one of 3 green levels, and blue values to one of 4 blue levels. You could picture this colorcube as a cube with dimensions of 2, 3, and 4. The index values assigned to the elements in that cube can be described by the following lookup table:
The distance between level changes in each channel of the lookup table is determined by the following formulas:
multipliers[0] = signof(dimensions[0])*1;
multipliers[i] = signof(dimensions[i])*
abs(multipliers[i-1]*dimension[i-1]);
A negative dimensions[i], so as to a negative multipliers[i], indicates that the values in a color ramp for channel i should appear in decreasing as opposed to increasing order.
For each channel i, the values of the levels are determined by the following formulas:
double delta = (dataMax - dataMin)/(abs(dimensions[i]) - 1); int levels[j] = (int)(j*delta + 0.5);
where dataMax and dataMin are the maximum and minimum values, respectively, for data type intype.
Whenever a colorcube is created, if lut != NULL, the lookup table will be filled according to the colorcube and supplied parameters like offset. For the example shown above, the lookup table will start from line 6. In this case, it is the user's responsibility to allocate memory for the lookup table.
The function takes the following arguments:
Internal data structure for image dithering.
Dimensions of the colorcube in the colormap structure.
Data type of the source image and the lookup table.
Data type of the destination indexed image.
Number of channels of the lookup table and source image.
Number of entries of the lookup table.
Index offset of the lookup table.
Lookup table.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageColorDitherFree(3MLIB), mlib_ImageColorErrorDiffusion3x3(3MLIB), mlib_ImageColorErrorDiffusionMxN(3MLIB), mlib_ImageColorOrderedDither8x8(3MLIB), mlib_ImageColorOrderedDitherMxN(3MLIB), attributes(5)
