cc [ flag... ] file... –lmlib [ library... ] #include <mlib.h> mlib_status mlib_MatrixMulShift_S16_S16_Mod(mlib_s16 *z, const mlib_s16 *x, const mlib_s16 *y, mlib_s32 m, mlib_s32 l, mlib_s32 n, mlib_s32 shift);
mlib_status mlib_MatrixMulShift_S16_S16_Sat(mlib_s16 *z, const mlib_s16 *x, const mlib_s16 *y, mlib_s32 m, mlib_s32 l, mlib_s32 n, mlib_s32 shift);
mlib_status mlib_MatrixMulShift_S16C_S16C_Mod(mlib_s16 *z, const mlib_s16 *x, const mlib_s16 *y, mlib_s32 m, mlib_s32 l, mlib_s32 n, mlib_s32 shift);
mlib_status mlib_MatrixMulShift_S16C_S16C_Sat(mlib_s16 *z, const mlib_s16 *x, const mlib_s16 *y, mlib_s32 m, mlib_s32 l, mlib_s32 n, mlib_s32 shift);
Each of these functions performs a multiplication of two matrices and shifts the result.
For real data, the following equation is used:
l-1 z[i*n + j] = {SUM (x[i*l + k] * y[k*n + j])} * 2**(-shift) k=0
where i = 0, 1, ..., (m - 1); j = 0, 1, ..., (n - 1).
For complex data, the following equation is used:
l-1 z[2*(i*n + j)] = {SUM (xR*yR - xI*yI)} * 2**(-shift) k=0 l-1 z[2*(i*n + j) + 1] = {SUM (xR*yI + xI*yR)} * 2**(-shift) k=0
where
xR = x[2*(i*l + k)] xI = x[2*(i*l + k) + 1] yR = y[2*(k*n + j)] yI = y[2*(k*n + j) + 1] i = 0, 1, ..., (m - 1) j = 0, 1, ..., (n - 1)
Each of the functions takes the following arguments:
Pointer to the first element of the result matrix, in row major order.
Pointer to the first element of the first matrix, in row major order.
Pointer to the first element of the second matrix, in row major order.
Number of rows in the first matrix. m > 0.
Number of columns in the first matrix, and the number of rows in the second matrix. l > 0.
Number of columns in the second matrix. n > 0.
Right shifting factor. 1 ≤ shift ≤ 16.
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
