man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_GraphicsFillArc_32(3MLIB)
Name
mlib_GraphicsFillArc, mlib_GraphicsFillArc_8, mlib_GraphicsFillArc_32, mlib_GraphicsFillArc_X_8, mlib_GraphicsFillArc_X_32, mlib_GraphicsFillArc_A_8, mlib_GraphicsFillArc_A_32, mlib_GraphicsFillArc_B_8, mlib_GraphicsFillArc_B_32, mlib_GraphicsFillArc_AB_8, mlib_GraphicsFillArc_AB_32 - draw filled arc
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_GraphicsFillArc_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c);
mlib_status mlib_GraphicsFillArc_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillArc_X_8(mlib_image *buffer, mlib_s16 x,
     mlib_s16 y, mlib_s32 r, mlib_f32 t1, mlib_f32 t2, mlib_s32 c,
     mlib_s32 c2);
mlib_status mlib_GraphicsFillArc_X_32(mlib_image *buffer, mlib_s16 x,
     mlib_s32 c2);
mlib_status mlib_GraphicsFillArc_A_8(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillArc_A_32(mlib_image *buffer, mlib_s16 x,
mlib_status mlib_GraphicsFillArc_B_8(mlib_image *buffer, mlib_s16 x,
     mlib_s32 a);
mlib_status mlib_GraphicsFillArc_B_32(mlib_image *buffer, mlib_s16 x,
     mlib_s32 a);
mlib_status mlib_GraphicsFillArc_AB_8(mlib_image *buffer, mlib_s16 x,
     mlib_s32 a);
mlib_status mlib_GraphicsFillArc_AB_32(mlib_image *buffer, mlib_s16 x,
     mlib_s32 a);
Description
Each of the mlib_GraphicsFillArc_*() functions draws a filled arc with the center at (x, y), radius r, start angle t1, and end angle t2.
Each of the mlib_GraphicsFillArc_X_*() functions draws a filled arc in Xor mode as follows:
    data[x,y] ^= c ^ c2
Each of the mlib_GraphicsFillArc_A_*() functions draws a filled arc with antialiasing.
Each of the mlib_GraphicsFillArc_B_*() functions draws a filled arc with alpha blending as follows:
    data[x,y] = (data[x,y] * (255 - a) + c * a) / 255
Each of the mlib_GraphicsFillArc_AB_*() functions draws a filled arc with antialiasing and alpha blending.
Parameters
Each of the functions takes some of the following arguments:
buffer
Pointer to the image into which the function is drawing.
x
X coordinate of the center.
y
Y coordinate of the center.
r
Radius of the arc.
t1
Start angle of the arc in radians.
t2
End angle of the arc in radians.
c
Color used in the drawing.
c2
Alternation color.
a
Alpha value for blending. 0 ≤ a ≤ 255.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_GraphicsFillCircle(3MLIB), mlib_GraphicsFillEllipse(3MLIB), attributes(5)
