cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
void mlib_VideoColorBGRAint_to_ABGRint(mlib_u32 *ABGR,
const mlib_u32 *BGRA, mlib_s32 w, mlib_s32 h, mlib_s32 dlb,
mlib_s32 slb);
The BGRA pixel stream is broken apart and recombined into an ABGR pixel stream. All pixel components are 8-bit unsigned integers. The buffers have dimensions w and h. Within each 32-bit input word, the component ordering is B (bits 31-24), G (bits 23-16), R (bits 15-8), and A (bits 7-0). Within each 32-bit output word, the component ordering is A (bits 31-24), B (bits 23-16), G (bits 15-8), and R (bits 7-0).
The function takes the following arguments:
Pointer to output buffer.
Pointer to input buffer.
Image width in pixels.
Image height in lines.
Linebytes for output buffer.
Linebytes for input buffer.
None.
mlib_VideoColorABGRint_to_ARGBint(3MLIB), mlib_VideoColorRGBAint_to_ABGRint(3MLIB), attributes(5)
