man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_VideoReversibleColorYUV2RGB_U8_S16(3MLIB)
Name
mlib_VideoReversibleColorYUV2RGB_U8_U8, mlib_VideoReversibleColorYUV2RGB_U8_S16, mlib_VideoReversibleColorYUV2RGB_S16_S16, mlib_VideoReversibleColorYUV2RGB_S16_S32 - reversible color space conversion for wavelet transformation
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoReversibleColorYUV2RGB_U8_U8(mlib_u8 *r,
     mlib_u8 *g, mlib_u8 *b, const mlib_u8 *y, const mlib_u8 *u,
     const mlib_u8 *v, mlib_s32 n, mlib_s32 depth);
mlib_status mlib_VideoReversibleColorYUV2RGB_U8_S16(mlib_u8 *r,
     mlib_u8 *g, mlib_u8 *b, const mlib_s16 *y, const mlib_s16 *u,
     const mlib_s16 *v, mlib_s32 n, mlib_s32 depth);
mlib_status mlib_VideoReversibleColorYUV2RGB_S16_S16(mlib_s16 *r,
     mlib_s16 *g, mlib_s16 *b, const mlib_s16 *y, const mlib_s16 *u,
mlib_status mlib_VideoReversibleColorYUV2RGB_S16_S32(mlib_s16 *r,
     mlib_s16 *g, mlib_s16 *b, const mlib_s32 *y, const mlib_s32 *u,
     const mlib_s32 *v, mlib_s32 n, mlib_s32 depth);
Description
Each of the functions provides support to reversible wavelet transformation. It is for reversible color space conversion.
Parameters
Each of the functions takes the following arguments:
r
Pointer to destination R component.
g
Pointer to destination G component.
b
Pointer to destination B component.
y
Pointer to source Y component.
u
Pointer to source U component.
v
Pointer to source V component.
n
Length of data.
depth
Number of bit planes required to store the original R, G, and B components.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_VideoReversibleColorRGB2YUV_U8_U8(3MLIB), attributes(5)
