cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoColorRGB2JFIFYCC422(mlib_u8 *y, mlib_u8 *cb,
mlib_u8 *cr, const mlib_u8 *rgb, mlib_s32 n);
The mlib_VideoColorRGB2JFIFYCC422() function performs color space conversion from RGB to YCbCr together with sampling rate conversion when used in the JPEG File Interchange Format (JFIF).
The function takes the following arguments:
Pointer to destination Y component row. y must be 8-byte aligned.
Pointer to destination Cb component row. cb must be 8-byte aligned.
Pointer to destination Cr component row. cr must be 8-byte aligned.
Pointer to source RGB multi-component row. rgb must be 8-byte aligned.
Length of Y component row. n must be even. The length of Cb and Cr component rows must be n/2. The length of the RGB multi-component row must be 3*n.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_VideoColorABGR2JFIFYCC420(3MLIB), mlib_VideoColorABGR2JFIFYCC422(3MLIB), mlib_VideoColorARGB2JFIFYCC420(3MLIB), mlib_VideoColorARGB2JFIFYCC422(3MLIB), mlib_VideoColorRGB2JFIFYCC420(3MLIB), attributes(5)
