cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageSConv3x3(mlib_image *dst, const mlib_image *src,
const mlib_s32 *hkernel, const mlib_s32 *vkernel, mlib_s32 scale,
mlib_s32 cmask, mlib_edge edge);
The mlib_ImageSConv3x3() function performs a separable 3x3 convolution on the source image by using the user-supplied kernel.
It uses the following equation:
m-1-dm n-1-dn
dst[x][y][i] = SUM SUM src[x+p][y+q][i]*h[p]*v[q]*2**(-2*scale)
p=-dm q=-dn
where m = 3, n = 3, dm = (m - 1)/2 = 1, dn = (n - 1)/2 = 1.
The function takes the following arguments:
Pointer to destination image.
Pointer to source image.
Pointer to the horizontal kernel.
Pointer to the vertical kernel.
Scaling factor.
Channel mask to indicate the channels to be convolved, each bit of which represents a channel in the image. The channels corresponding to one bits are those to be processed. For a single-channel image, the channel mask is ignored.
Type of edge condition. It can be one of the following:
MLIB_EDGE_DST_NO_WRITE MLIB_EDGE_DST_FILL_ZERO MLIB_EDGE_DST_COPY_SRC MLIB_EDGE_SRC_EXTEND
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageConv2x2(3MLIB), mlib_ImageConv2x2_Fp(3MLIB), mlib_ImageConv2x2Index(3MLIB), mlib_ImageConv3x3(3MLIB), mlib_ImageConv3x3_Fp(3MLIB), mlib_ImageConv3x3Index(3MLIB), mlib_ImageConv4x4(3MLIB), mlib_ImageConv4x4_Fp(3MLIB), mlib_ImageConv4x4Index(3MLIB), mlib_ImageConv5x5(3MLIB), mlib_ImageConv5x5_Fp(3MLIB), mlib_ImageConv5x5Index(3MLIB), mlib_ImageConv7x7(3MLIB), mlib_ImageConv7x7_Fp(3MLIB), mlib_ImageConv7x7Index(3MLIB), mlib_ImageConvKernelConvert(3MLIB), mlib_ImageConvMxN(3MLIB), mlib_ImageConvMxN_Fp(3MLIB), mlib_ImageConvMxNIndex(3MLIB), mlib_ImageConvolveMxN(3MLIB), mlib_ImageConvolveMxN_Fp(3MLIB), mlib_ImageSConv3x3_Fp(3MLIB), mlib_ImageSConv5x5(3MLIB), mlib_ImageSConv5x5_Fp(3MLIB), mlib_ImageSConv7x7(3MLIB), mlib_ImageSConv7x7_Fp(3MLIB), mlib_ImageSConvKernelConvert(3MLIB), attributes(5)
