cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_ImageMulAlpha_Fp(mlib_image *dst, const mlib_image *src,
mlib_s32 cmask);
The mlib_ImageMulAlpha_Fp() function multiplies floating-point color channels by the alpha channel on a pixel by pixel basis.
It uses the following equation:
dst[x][y][c] = src[x][y][c] * src[x][y][a]
where c and a are the indices for the color channels and the alpha channel, respectively, so c != a.
The function takes the following arguments:
Pointer to destination image.
Pointer to source image.
Channel mask to indicate the alpha channel. Each bit of the mask represents a channel in the image. The channel corresponding to the 1 bit of cmask is the alpha channel.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageMulAlpha(3MLIB), mlib_ImageMulAlpha_Inp(3MLIB), mlib_ImageMulAlpha_Fp_Inp(3MLIB), attributes(5)
