cc [ flag... ] file... –lmlib [ library... ] #include <mlib.h> void *mlib_memcpy(void *dst, const void *src, size_t n);
The mlib_memcpy() function copies n bytes from memory area src to dst. It returns dst. The memory areas may not overlap. Use mlib_memmove() if the memory areas do overlap.
This function is a wrapper of the standard C function memcpy().
The function takes the following arguments:
Pointer to the destination.
Pointer to the source.
Number of bytes to be copied.
The function returns a pointer to the destination.
mlib_memmove(3MLIB), mlib_memset(3MLIB), memory(3C), attributes(5)
