man pages section 3: Multimedia Library Functions
Exit Print View
Updated: July 2014
mlib_VideoInterpXY_S16_U8_16x16(3MLIB)
Name
mlib_VideoInterpXY_S16_U8_16x16, mlib_VideoInterpXY_S16_U8_16x8, mlib_VideoInterpXY_S16_U8_8x16, mlib_VideoInterpXY_S16_U8_8x8, mlib_VideoInterpXY_S16_U8_8x4 - half-pixel interpolation in the X and Y directions for motion compensation
Synopsis
cc [ flag... ] file... –lmlib [ library... ]
#include <mlib.h>
mlib_status mlib_VideoInterpXY_S16_U8_16x16(mlib_s16 *mc_block,
     const mlib_u8 *ref_block, mlib_s32 frm_stride,
     mlib_s32 fld_stride);
mlib_status mlib_VideoInterpXY_S16_U8_16x8(mlib_s16 *mc_block,
mlib_status mlib_VideoInterpXY_S16_U8_8x16(mlib_s16 *mc_block,
mlib_status mlib_VideoInterpXY_S16_U8_8x8(mlib_s16 *mc_block,
mlib_status mlib_VideoInterpXY_S16_U8_8x4(mlib_s16 *mc_block,
Description
Each of these functions performs half-pixel interpolation in the X and Y directions for a reference block of data type mlib_u8 and a current block of data type mlib_s16. In this mode, the output of this function must be added to the IDCT output to reconstruct the block in the current frame. Thus, the stride applies only to the input reference block.
Parameters
Each of the functions takes the following arguments:
mc_block
Pointer to the motion-compensated reference block. mc_block must be 8-byte aligned.
ref_block
Pointer to the reference block.
frm_stride
Stride, in bytes, between adjacent rows in a frame in the reference block. frm_stride must be a multiple of eight.
fld_stride
Stride, in bytes, between adjacent rows in a field in the reference block. fld_stride must be a multiple of eight.
Return Values
Each of the functions returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See also
mlib_VideoAddBlock_U8_S16(3MLIB), mlib_VideoCopyRef_S16_U8(3MLIB), mlib_VideoCopyRef_S16_U8_16x16(3MLIB), mlib_VideoCopyRef_U8_U8(3MLIB), mlib_VideoCopyRef_U8_U8_16x16(3MLIB), mlib_VideoCopyRefAve_U8_U8(3MLIB), mlib_VideoCopyRefAve_U8_U8_16x16(3MLIB), mlib_VideoH263OverlappedMC_S16_U8(3MLIB), mlib_VideoH263OverlappedMC_U8_U8(3MLIB), mlib_VideoInterpAveX_U8_U8(3MLIB), mlib_VideoInterpAveX_U8_U8_16x16(3MLIB), mlib_VideoInterpAveXY_U8_U8(3MLIB), mlib_VideoInterpAveXY_U8_U8_16x16(3MLIB), mlib_VideoInterpAveY_U8_U8(3MLIB), mlib_VideoInterpAveY_U8_U8_16x16(3MLIB), mlib_VideoInterpX_S16_U8(3MLIB), mlib_VideoInterpX_S16_U8_16x16(3MLIB), mlib_VideoInterpX_U8_U8(3MLIB), mlib_VideoInterpXY_S16_U8(3MLIB), mlib_VideoInterpXY_U8_U8(3MLIB), mlib_VideoInterpXY_U8_U8_16x16(3MLIB), mlib_VideoInterpY_S16_U8(3MLIB), mlib_VideoInterpY_S16_U8_16x16(3MLIB), mlib_VideoInterpY_U8_U8(3MLIB), mlib_VideoInterpY_U8_U8_16x16(3MLIB), mlib_VideoP64Decimate_U8_U8(3MLIB), mlib_VideoP64Loop_S16_U8(3MLIB), mlib_VideoP64Loop_U8_U8(3MLIB), attributes(5)
