Oracle EDR InfiniBand Switch and Virtualized I/O Systems Administration Guide
Exit Print View
Updated: November 2016
HTTP OIDs
This table lists HTTP service object identifiers supported by the SUN-ILOM-CONTROL-MIB MIB.
Description of Task or Activity
Action
MIB OID
Display or set whether the embedded web server is running and listening on the HTTP port.
read
write
ilomCtrlHttpEnabled
Display or set the port number that the embedded web server should listen to for HTTP requests.
read
write
ilomCtrlHttpPortNumber
Display or set whether the embedded web server should redirect HTTP connections to HTTPS.
read
write
ilomCtrlHttpSecureRedirect
Related Information
