Exit Print View
If network management occurs over an IPv4 network, use this task to enable IPv4 network connectivity for the SP and network management interface.
-> set /SP/network/ state=enabled Set 'state' to 'enabled' [ipv4-only] ->
Configure IPv4 Routing Properties (Oracle ILOM CLI)
Disable IPv4 Management Network Routing (Oracle ILOM CLI)
Test the Management Network Configuration (Oracle ILOM CLI)
