Oracle EDR InfiniBand Switch and Virtualized I/O Systems Administration Guide
Exit Print View
Updated: November 2016
Disable IPv4 Management Network Routing (Oracle ILOM CLI)
At any time, you can disable IPv4 routing for the network management interface. When disabled, IPv4 routing properties remain configured, but IPv4 traffic is not supported on the SP.
  • Type:
    -> set /SP/network/ state=disabled
    Set 'state' to 'disabled' [ipv4-only]
Related Information
