The switch has an IB switch chip that is networking switch 0. By default, this switch is brought online whenever the switch is powered on. While the switch is running, you can use this task to reset the IB switch chip.
-> reset /System/Networking/Switches/Switch_1 Are you sure you want to reset /System/Networking/Switches/Switch_1 (y/n)? y ->
