To enable name services within the SP, Oracle ILOM must be configured as a DNS client.
-> set /SP/clients/dns nameserver=123.45.67.89,123.45.67.90,123.45.67.91 Set 'nameserver' to '123.45.67.89,123.45.67.90,123.45.67.91' [123.45.67.89, 123.45.67.90, 123.45.67.91] ->
If you need multiple name servers for redundancy, you can configure a maximum of three. The order you specify is the order in which servers are tried, if the preceding servers are unavailable. If you specify multiple name servers, separate them with a comma, but no blank spaces.
-> set /SP/clients/dns retries=3 Set 'retries' to '3' ->
You can configure up to 4 retries. Setting the retry value to 0 disables retrying so that only the first communication attempt is made.
-> set /SP/clients/dns timeout=10 Set 'timeout' to '10' ->
You can configure a timeout between 1 and 10 seconds.
-> set /SP/clients/dns automatons=enabled nameserver=123.45.67.89,123.45.67.90 searchpath='us.companyq.com,canada.companyq.com' Set 'automatons' to 'enabled' Set 'nameserver' to '123.45.67.89,123.45.67.90' Set 'searchpath' to 'us.companyq.com,canada.companyq.com' ->
