You can control the properties of the console connection to the switch. For example, you can enable or disable console logging or set the number of lines displayed in the console window.
-> set /HOST/console/ logging=enabled Set 'logging' to 'enabled' ->
-> set /HOST/console/ line_count=16 Set 'line_count' to '16' ->
-> set /HOST/console/ pause_count=99 Set 'pause_count' to '99' ->
-> set /HOST/console/ start_from=beginning Set 'start_from' to 'beginning' ->
